Problem charge easychesterfiled
nixa3d
Messaggio da nixa3d »
Hello everybody, I´m a beginner with Cinema4d and i have seen our plugins ... are wonderful. :)
I tried with a free plugin EasyChesterField and dont charge it my C4D r16
My OS is win 8.1
where is the problem? Will ocurred with the rest plugins c4dzone?
Thanks a lot of
cappellaiomatto
Re: Problem charge easychesterfiled
Hi
This is very strange, I don't know where is the problem within your computer....I need more information
Did you install the plugin correctly copying it within c4d plugin folder?
Do you see it in the plugin manager?
Open script->console and copy here the text if present
I wait for your reply
nixa3d
Thanks for reply soon....
this is in my consola:
// Xfrog 5.0 (Nov 10 2014) loaded.
CA Super Deformer Pack v1.37, ©2013-2014 Curious Animal Limited
CA Mega Deformer Pack v1.05, ©2014 Curious Animal Limited
C4D: 16050
SysInfo: 32
WindowGenerator v1.6_20120116 loaded
PlacementTool loaded
-- Drop To Floor v1.1 © 2009
-- Ivy Grower v1.2.1 © 2011
PipeObject 1.1
PzrForC4D - PluginStart
PzrForC4D - PluginStart - PzrForC4D registered
PzrForC4D - PluginStart - SceneHook registered
// Remotion: SuperVoxels 2013 (Nov 25 2013) loaded. ;)
// www.remotion4d.net
Tools4D Vectorizer Professional - Version 1.47 Installed
Tools4D White Lights version 2.5
White Lights 2.12
TurbulenceFD v1.0 Build 1372 64Bit Sep 24 2014
Copyright (c) 2008-2012 Jawset Visual Computing. All rights reserved.
Log file:
C:/Users/nixa3d/AppData/Roaming/jawset/turbulence.log
VrayForC4D Win64 1.8.1.32 Oct 10 2013 | www.vrayforc4d.com
Number of VRay Standalone DR Slave Nodes Authorized: 10
Cineversity.com's CV-CV-Boole Union / Add v1.0.0 loaded. (C) 2015 MAXON Computer, Inc.
Cineversity.com's CV-CV-Boole Subtract v1.0.0 loaded. (C) 2015 MAXON Computer, Inc.
Cineversity.com's CV-CV-Boole Intersect v1.0.0 loaded. (C) 2015 MAXON Computer, Inc.
Cineversity.com's CV-CV-Boole Without v1.0.0 loaded. (C) 2015 MAXON Computer, Inc.
Cineversity.com's CV-CV-Boole Connect v1.0.0 loaded. (C) 2015 MAXON Computer, Inc.
Traceback (most recent call last):
File "'easychesterfield.pypv'", line 592, in <module>
File "D:\Dise_AXON\CINEMA 4D R16\resource\modules\python\Python.win64.framework\lib\xml\dom\minidom.py", line 1918, in parse
return expatbuilder.parse(file)
File "D:\Dise_AXON\CINEMA 4D R16\resource\modules\python\Python.win64.framework\lib\xml\dom\expatbuilder.py", line 922, in parse
fp = open(file, 'rb')
IOError: [Errno 2] No such file or directory: 'D:\\Dise\xc3\xb1o\\MAXON\\CINEMA 4D R16\\plugins\\easychesterfield\\res/default.xml'
E02
SuperText.pype: Cannot load plugin because the encryption has been updated. Please re-encrypt the Python Plugin.
SuperTextEditCommand.pype: Cannot load plugin because the encryption has been updated. Please re-encrypt the Python Plugin.
== NextLimit RealFlow plug-in v2.1.2 ==
== NextLimit RealFlow RenderKit plug-in v1.1.4 (for SDK v3.0.2.0017) ==
smInDragOrPlaying false
E02
nixa3d
my folder is
D:/Diseño/MAXON/Cinema4D R16/plugins/easychesterfield
and i see that there isnt in my consola "D:\Dise_AXON\CINEMA 4D" (some letters are missing)
is problem letter "Ñ" ?( tipical Spanis) :-)
cappellaiomatto
You have something wrong with your cinema 4d installation but I don't know where is the problem....it's the first time I see this kind of error.
It seems that python lib doesn't work correctly or it cannot load the configuration file of the plugin.
may be the spanish language cause this problem but I'm not sure....we have got a lot of spanish customers and nobody complains about this kind of errors.
I see from the log that the installation path is not clear
became this one
the ñ probably causes python library to fail locating the path.
Did you copy all the files and folder of easychesterfield plugin?
try to install cinema 4d in a folder without special char or much better in the default program folder.
hope this help.
nixa3d
Thanks for answering so fast.
I imagined something like.Try to change the letter "ñ"
I can not make the default path as my main OS disk because it is 128GB SSD and is almost full :)
I hope enjoy this plugin and all that you have to really are fascinating. Thanks, thanks
thanks again
Best regards
cappellaiomatto
thanks to you :)
nixa3d
Faced again thank you for your help.
Indeed the problem was in the DISEÑO folder with the letter Ñ, have moved folder MAXON whitout DISEÑO folder and load the script perfectly, I hope this also serves to Spanish future :-)
i´m very happy.... :oops:
Thanks again
cappellaiomatto
thanks for feedback
