Tuilegenrator does not work ???
can anybody help me please.
I've bought a Tuilgenerator and it worked well.
But now, 2 month later, I don't get anything.
When pressing "Build / Update Mantle" I get this message in the Console:
Traceback (most recent call last):
File "'tuilegenerator.pypv'", line 3774, in Command
File "'tuilegenerator.pypv'", line 2752, in Analizza
AttributeError: 'NoneType' object has no attribute 'GetFirstObject'
What do I have to do?
Thanks a lot
- cappellaiomatto
- Moderatore
Re: Tuilegenrator does not work ???
Try to optimize the mesh with the optimize command.
Did you import it from other 3d software?
If you don't solve upload here the mesh without materials and indicate the region you want to cover with tiles I will check it
thanks for ansering.
For the test I use a fresh generated Polyone-Objekt, 200x200 cm, 1 face, normal side to up, with no material
Could it be something to do witch licensing?
Where do I have to place the activation code?
Thanks
1st reinstall
2nd although "real time update" is activated i have to press "generate mantle"
Solved / closed
