How Do You start Cinema 4D?
lemo76
Messaggio da lemo76 »
What's the First thing you put in your Cinema 4D scene when you start it?
What is your 'most used' tool?
Re: How Do You start Cinema 4D?
Mmmm I think my most used tools is the cube object :) usually I start to model something so the cube is my best object. :) after the Cube I use offen the area light :)
synapsys
Messaggio da synapsys »
oh, nice question :) usually I'm starting with spline because my best tools are NURBS, I'm not able to use the poly right not :)
lemo76
Yeah. My most used tool is the matrix extrude tool and hypernurbs. I can create some extremely interesting shapes, then I can soften them! I start off with a cube and then I crank the segments up and make it editable
