I've downloaded plugin yet one time(actually i've made it two more times... accidentallymasterzone ha scritto: - when you installed the DR on your cinema 4D or NET client the plugin start it's window when you launch it form plugins menu?
- are you decompressed DR folder correctly? Some times if you are using windows internal decompressing system some errors about decrypting folder my appears.
- If plugin doen't start from plugin menu, did you find the PDF "edit-permissions.pdf" in the documentation folder?
- what kind OS are you using? Mac or Pc?
- if plugin is correctly installed and it's windows popup from plugin menu when you run it did you selected a shared folder where all computer can access for save chunks and get the cinema4D file?
- did you wrote Exatly the name of cinema4d scene with extension? Xxx.c4d?
- when you clic on start rendering process what happen?
About DR
About DR
Re: Moved ))
Feel free to write us for other tips
