About Poly breaker
About Poly breaker
I have a huge amount of projects that I would need to create this kind of pathways and I was thinking in a fast way to make it so I came across with poly breaker and I´m wondering if this could do the job, having a sweeped nurbs object and then make it editable in order to have the pattern, is it possible?
I own the Prime flavor, it is compatible or I would need studio for that? BTW no need for animation or anything just to make the pathways.
Best regards
JC
- Creating_Garden_Pathways_1_P1010543.JPG (139.02 KiB) Visto 5070 volte
- cappellaiomatto
- Moderatore
Re: About Poly breaker
Hi jc4d, unfortunately the polybreaker is not the right choise for making this kind of meshes.jc4d ha scritto:Hi all,
You can controll the break regularity but it is impossible to obtain the pattern you need and also you have to separate manually all single pieces.....so it's much better to do it in another ways.
But.....thanks for suggestion......It may become a new plugin in the future
I don't know Prime flavor so I cannot reply to you about this questionjc4d ha scritto: I own the Prime flavor, it is compatible or I would need studio for that? BTW no need for animation or anything just to make the pathways.
Best regards
JC
PS
Please for the future do not upload image as link url, use our upload system next time, Thanks
- polybreaker.jpg (39.85 KiB) Visto 5069 volte
cappellaiomatto ha scritto:Hi jc4d, unfortunately the polybreaker is not the right choise for making this kind of meshes.
Just mind skecthing a littlecappellaiomatto ha scritto:You can controll the break regularity but it is impossible to obtain the pattern you need and also you have to separate manually all single pieces.....so it's much better to do it in another ways.
The plugin don´t produce each piece as a separate object?
Maybe using normal scale or normal move could create the separation?
Please... and take my money when you release it, a pathways plugincappellaiomatto ha scritto:But.....thanks for suggestion......It may become a new plugin in the future
I´m tempted to buy it, but if the plugin requires internally some mograph things then I can´t.cappellaiomatto ha scritto:I don't know Prime flavor so I cannot reply to you about this question
Ok, no problemcappellaiomatto ha scritto:Please for the future do not upload image as link url, use our upload system next time, Thanks
Cheers
JC
- cappellaiomatto
- Moderatore
Yes it creates single objects but believe me....you can waste a lot of time doing it with polybreaker....jc4d ha scritto: Just mind skecthing a little![]()
If I will publish the pathway generator you will be the first to be contact
Bye
Thank you so much I really appreciate your honestycappellaiomatto ha scritto:Yes it creates single objects but believe me....you can waste a lot of time doing it with polybreaker....![]()
Awesomecappellaiomatto ha scritto:If I will publish the pathway generator you will be the first to be contact
Cheers
JC
