Target soft switch
Mihai
Target soft switch
Messaggio da Mihai »
Hi guys!
I need some help on a school project
I ve decided to make a photo slideshow based on a rubik cube explosion.
Each side has a picture in it.
The problem is i cant set a spline around all the cubes, its too hard
And another thing , Target , as i learned with the cinema 4d tags, switches instantly.
How can I switch target solfty, like turning your head gently to watch another thing
TY very much for help
Cheers,
Michel
P.S project in attachment
frame2.rar
(16.46 KiB) Scaricato 213 volte
cappellaiomatto
Re: Target soft switch
Hi Michel welcome to our forum :)
Mihai ha scritto:Hi guys!
they are only 27 cubes.....what is hard on moving 27 cubes? it's very simple and it's not mandatory to animate them with spline, you can do it by hand just storing position and rotation of cubes
the animation steps are very simple
time -> action -> store
I see your scene .....an advice....learn to animate by hand your objects ....do not use dynamics if it's not strictly necessary, a good animator does not use them
Mihai ha scritto: And another thing , Target , as i learned with the cinema 4d tags, switches instantly.
you have to animate the target not the source object
