Chain Generator Plugin scaling help
Sappy
Messaggio da Sappy »
Hello, I want to scale down chain generated chain to my life-size bike, but when I scale animation stops working, I need 65 rings, but after scaling there is errors (10 rings on one path node). I scaled up bike to 10 meters in length and everything okay, but that not great solution.
I hope you guys could help me with this. Thanks.
chain.zip
My project file for chain.
(100.76 KiB) Scaricato 494 volte
Re: Chain Generator Plugin scaling help
You should provide the link to the plug-in or barely anyone could try your file.
Sappy
Woops ! Sorry, I didn't see you were (correctly) posting on our plugin support. Shame on me :)
cappellaiomatto
Sappy ha scritto:Hello, I want to scale down chain generated chain to my life-size bike, but when I scale animation stops working, I need 65 rings, but after scaling there is errors (10 rings on one path node). I scaled up bike to 10 meters in length and everything okay, but that not great solution.
Hi sappy
unfortunately there is no great solution except scaling up the other content.
This is fault of Cinema 4D internal calculation and approximation of the spline.....on small scale it lose thousandths that are essential for the correct movement of the chain.
Sorry but I cannot help you
Sappy
Just wanted to ask, is there any change on this issue after R16 update?
cappellaiomatto
Hi sappy
Nothing has change after r16 update pfiu
