Team render vray 1.9 errore
jessica89
Messaggio da jessica89 »
ciao a tutti, ho provato a far andare il team render utilizzando vray. Ho abilitato il vray DR, impostato l'ip del pc nel quale ho installato il client team render, controllato gli shader, luci etc ma quando lancio il render nella coda render in team con vray dopo 3 secondi mi da: "errore-fuori memoria".
Ho provato con un semplicissimo cubo con un materiale e una luce semplice ma nada sempre solito errore.(senza vray il team render funziona). :(
Grazie mille.
Jessica.
Vi posto il file log:
- <batchrender>
- <environmentinfo>
- <machineinfo>
<machinename>PCJESSICA-PC</machinename>
<username>pc jessica</username>
<processortype>GenuineIntel, stepping 9, model 10, instruction family 6</processortype>
<processorname>Intel Core i5-3570K CPU</processorname>
<processornumber>4</processornumber>
<ostype>WINDOWS 64 BIT</ostype>
<osversion>Windows 7, 64 Bit, Ultimate Edition (build 7600)</osversion>
<oglvendorname>NVIDIA Corporation</oglvendorname>
<oglrendername>GeForce GTX 660/PCIe/SSE2</oglrendername>
<oglversion>3.2.0</oglversion>
</machineinfo>
- <c4dinfo>
<c4dversion>15008</c4dversion>
<c4dplugins>addons alembic allplan ArchiCADExchange bitmapfilter bp2lw bp2max bp2maya bp2xsi browser characteranim cameramapper collada14 collada15 compositing dwg dwgobjects fbx expressiontag graphviewcore modeling motioncam netrender newman objects onlinehelp onlineupdater OpenEXR python relaxuv sculpt sculptbrushes shader sla spacemouse texturemanager updatemerge xtensions advancedrender cineman sky archigrass walkthrough dynamics2 iges OkinoComClient hair ca2 clothilde mocca motiongraphics sketch thinkingparticles tpoperators SetPATH VrayBridge15</c4dplugins>
</c4dinfo>
</environmentinfo>
- <fileinfo>
<filename>ANTOLINI CANNES -1 001.c4d</filename>
<filepath>C:\Users\pc jessica\Desktop\MODELLO CINEMA\prova1 -1</filepath>
- <renderdatainfo>
<rendersettings>definitiva</rendersettings>
<camera>1</camera>
<width>2362</width>
<height>1181</height>
<filmaspect>2</filmaspect>
<pixelaspect>1</pixelaspect>
<fps>30</fps>
<from>0</from>
<to>0</to>
<steps>1</steps>
- <saveinfo>
<imagepath>C:\Users\pc jessica\Desktop\MODELLO CINEMA\prova1 -1</imagepath>
<imagedepth>8</imagedepth>
<imageformat>TIFF (Livelli PSD)</imageformat>
</saveinfo>
- <videopost>
<effect id="1019782" name="VrayBridge" />
</videopost>
</renderdatainfo>
</fileinfo>
- <renderinfo>
<imageinfo>00:00:00</imageinfo>
</renderinfo>
- <batchinfo>
<added>01/08/2014, 12:20:56</added>
<started>01/08/2014, 12:21:05</started>
<rendertime>00:00:00</rendertime>
<result>Errore - Fuori Memoria</result>
</batchinfo>
</batchrender>
bird
Re: Team render vray 1.9 errore
Messaggio da bird »
:o :shock:
team render di cinema4D non e' compatibile con vray...
devi usare il suo Vray DR contenuto nella 1.9 di vray...
ale
masterzone ha scritto:team render di cinema4D non e' compatibile con vray...
ale
Ammetto di non aver mai indagato a riguardo, tuttavia sono abbastanza sicuro che Vray 1.9 funzioni anche via Teamrender.
Dovrebbe essere il metodo migliore per le animazioni, mentre per gli still la via più efficace è il DR.
Per fugare ogni dubbio meglio chiedere a Stefan.
Trystero
Messaggio da Trystero »
Sirio76 ha scritto: sono abbastanza sicuro che Vray 1.9 funzioni anche via Teamrender.
Anch'io credevo che i due sistemi non fossero compatibili, ma poco fa ho letto questa risposta di Stefan Laub:
http://forum.vrayforc4d.com/index.php?threads/18527/
A parte la solita illeggibilità a causa degli errori (possibile che scriva sempre of invece di off?) mi sembra di decifrare che sia possibile usare il Team Render di C4D con Vray.
Ma non ho assolutamente capito come e non ho trovato istruzioni nel sito ufficiale.
Trystero
Trystero ha scritto:ho letto questa risposta di Stefan Laub:
(...) mi sembra di decifrare che sia possibile usare il Team Render di C4D con Vray. Ma non ho assolutamente capito come e non ho trovato istruzioni nel sito ufficiale.
Ci sono riuscito, non so bene come, ma Vray + C4D Team Render funziona. E il bello è che ci sono riuscito capendo in modo sbagliato il messaggio di Laub.
Ho installato Vray 1.9b in Cinema 4D Team Render Client, nello stesso identico modo usato per installarlo in Cinema 4D. Ma così non andava, uscivano egli errori nel Team Render Client che a un certo punto si bloccava.
Ho riletto il confuso testo di Laub (possibile che non si affidi a un "correttore di bozze" quando deve scrivere delle istruzioni importanti?) e mi è sembrato di capire che dicesse di rinominare il Cinema 4D TeamRender Client come Cinema 4D.
L'ho fatto e in questo modo non compariva più nessun errore nella schermata del Team Render rinominato, e i due "fotogrammi" venivano renderizzati regolarmente. Due perché (non si sa perché) Vray + Team Render funziona solo con almeno due fotogrammi.
Per me era solo un test, per capire se era possibile renderizzare con due Mac un modello in cui i materiali fossero quelli standard di Vray, con le texture normali, non convertite in Vray Shader che mi avrebbe permesso di fare un Vray Distributed Render.
Però, nonostante abbia funzionato, avevo capito male, secondo Laub non c'era da rinominare niente.
Alla fine credo di aver trovato il motivo del malfunzionamento.
Probabilmente in Vray ci sono linee di codice in cui vengono cercati certi elementi in precise directory. Se anche solo una lettera è diversa esce l'errore.
Il nome dell'applicazione che viene cercata è "Team Render Client", non quello originale che compare con l'installazione, ovvero "CINEMA 4D TeamRender Client":
Funziona anche rinominandolo come "CINEMA 4D", immagino per lo stesso motivo.
robertodandy
Messaggio da robertodandy »
buon giorno, esiste una guida dettagliata per l'utilizzo di team render?
utilizzo C4d R15 con vray.
Quando aggiungo una macchina alla lista di team render mi segnala che la versione del software non è abilitata a questo utilizzo.
Credo di non aver capito bene, devo installare una versione particolare di C4D client o va bene quella che ho?
pippogol92
Messaggio da pippogol92 »
Ciao a tutti, mi ricollego a questa discussione per sapere se qualcuno è riuscito ad utilizzare il team render + vray su un singolo fotogramma.
Riesco tranquillamente ad utilizzare questo sistema per la renderizzazione di animazioni ma se volessi renderizzare un singolo fotogramma mi da errore. Qualcuno sa se esiste qualche modo per risolvere? grazie mille :)
Trystero
pippogol92 ha scritto:e volessi renderizzare un singolo fotogramma mi da errore. Qualcuno sa se esiste qualche modo per risolvere? grazie mille :)
Credo non sia possibile, confermato anche da Laub nel forum di Vray.
L'unico modo è impostare almeno 2 fotogrammi.
nafta
Contatta:
Messaggio da nafta »
Salve scusate se mi inserisco in questa vecchia conversazione. Volevo un aiuto perché sto cercando di fare la stessa cosa con TeamRender di cinema 4D R18 e V-ray 3.4. Seguendo le indicazioni di Trystero ho installato cinema 4d R18 su due macchine, sulla macchina 1 ho configurato il TeamRender Server sulla macchina 2 ho configurato TeamRender Client con installato V-ray 3.4.
Se lancio un render molto semplice tanto per fare una prova il TeamRender Client mi da un errore che vi allego.
questo è il log del TeamRender Server macchina 1
Number of VRay Standalone DR Slave Nodes Authorized: -1
/Users/WorkStationJelux/Library/Preferences/MAXON/CINEMA 4D R18_50E4FAD5/VrayBridgeLog
[Vb Info]: VrayBridge start : Sunday, 28 May 2017 [05/28/17] at 00:13:41
2017/05/28 00:13:41 Service started on port 5402
2017/05/28 00:13:41 | WorkStationJelux.local:5402
2017/05/28 00:13:41 | : 192.168.200.105:5402
2017/05/28 00:13:41 Webserver started on port 8080
questo è il log del TeamRender Client macchina 2
[VB NOTE:] hash 0aa1892
VrayForC4D Net Client
/Users/geppo/Library/Preferences/MAXON/CINEMA 4D R18_50E4FAD5/VrayBridgeLog
[Vb Info]: VrayBridge start : Sunday, 28 May 2017 [05/28/17] at 00:17:15
2017/05/28 00:17:16 Service started on port 5401
2017/05/28 00:17:16 | Segreteria.local:5401
2017/05/28 00:17:16 | : 192.168.200.108:5401
2017/05/28 00:19:14 Grabbed Render-Job 'pv' from machine 'WorkStationJelux'
2017/05/28 00:19:14 Creato Asset 'bozza_3d.c4d'
2017/05/28 00:19:14 Downloaded Asset(s) in 0.013 seconds
2017/05/28 00:19:14 Start Rendering for Machine WorkStationJelux
2017/05/28 00:19:14 Assigned Frames 0 - 0
2017/05/28 00:19:14 Rendering frame 0 of job 'pv'
[Vb Error*]: Error loading plugin library "/Applications/MAXON/CINEMA 4D R18/plugins/VrayBridge/Libs64/plugins/libvray_MtlOSL.so": dlopen failed: dlopen(/Applications/MAXON/CINEMA 4D R18/plugins/VrayBridge/Libs64/plugins/libvray_MtlOSL.so, 5): Library not loaded: ./li
[Vb Error*]: Error loading plugin library "/Applications/MAXON/CINEMA 4D R18/plugins/VrayBridge/Libs64/plugins/libvray_TexOSL.so": dlopen failed: dlopen(/Applications/MAXON/CINEMA 4D R18/plugins/VrayBridge/Libs64/plugins/libvray_TexOSL.so, 5): Library not loaded: ../.
[Vb Error*]: Duplicate plugin IDs: GeomParticleSystem and GeomParticleSystem
2017/05/28 00:20:21 Statistiche Peer-to-Peer :
> WorkStationJelux Velocità-Download 11.49 MiB\s (1x)
Fine Statistiche Peer-to-Peer
Mentre sulla macchina Client mi da questo
/Users/geppo/Desktop/Untitled
[Vb Info]: VrayBridge start : Thursday, 22 June 2017 [06/22/17] at 00:29:35
2017/06/22 00:29:35 Service started on port 5401
2017/06/22 00:29:35 | Mac-Pro.local:5401
2017/06/22 00:29:35 | : 192.168.200.104:5401
2017/06/22 00:32:07 Grabbed Render-Job 'rq' from machine 'WorkStationJelux'
2017/06/22 00:32:08 Creato Asset 'ID10_W14_Scena_01.c4d'
2017/06/22 00:32:08 Creato Asset 'light map.tif'
2017/06/22 00:32:09 Scaricando Asset
2017/06/22 00:32:09 Downloaded Asset(s) in 1.313 seconds
2017/06/22 00:32:11 (Errore) Render-Lavoro fallito: Alcuni plugin usati in questa scena sono scomparsi.|Salvando puoi causare la perdita dei dati dei plugin!|Plugin 'Contenitore' (ID 1029700)
2017/06/22 00:32:11 Statistiche Peer-to-Peer :
> WorkStationJelux Velocità-Download 34.61 MiB\s (6x)
Qualcuno e cosi gentile da dirmi dove sbaglio, ho effettuato l'installazione di cinema 4d e v-ray come da manuale sulle due macchine ma non riesco ad usarlo.
Grazie mille
