Problems with animation render between two mix materials
Quim
Messaggio da Quim »
Hi.
I'm using vray for rendering an animation of a character in cinema 4D. When the armor of this character is moving. The second shader scratches material is not fixed. I´m using a vertex map for mix those two materials.
Can someone help me?
If I use the render engine cinema 4D I´ve not problem with this render animation
Vertex map
Vertex map
vertex map.jpg (123.5 KiB) Visto 2114 volte
Frame two
Frame two
Frame one
Frame one
Re: Problems with animation render between two mix materials
seems you have a overlapping polygons...I'm not shure but by take a look into the editor screenshot seems to be the overlapping. Do you have two objects?
