Problem Vray Material and Tag
How can i move ( Tag Uv ) two materials by separate?
By example
1) Wood - Dust ( Mixed Material with alpha ) i want to rotate only ¨ Dust ¨ but when i do this both materials move.
Thanks so much in advance.
Re: Problem Vray Material and Tag
This method is only way to move two tags separately.
So,
1) make the wood the first material tag of your object
2) put the second "dust" material tag into the object
3) put an alpha channel into the material weight layer with a black and white image on the "dust" material to make it trasparent itself
4) turn on the "mix material" option into the second "dust" material tag
vray should mix the second tag with the previous tag
