Bump material in viewport
kilmyneo
Messaggio da kilmyneo »
Hello,
Is there a way to see Bump Material in viewport?.
I am using dots in bump material applied to an object but i want to scale and move properly but i can´t visualize it.
Thanks in advance.
Antonio Petit Cwirko
Re: Bump material in viewport
Hello Antonio
It may depends by vray release and what kind of informations it send to cinema viewport.
Usually if you turn on "enhanced OpenGL" cinema can show you real time bump, but if this option is on and you don't see it with a vray material, maybe it doesn't supported by vray + cinema.
A tips:
Copy the shader or texture into diffuse channel so you can visualize it for a moment, so you can adjacent it and remove it after.
kilmyneo
Hello MasterZone,
Thanks so much for reply i really appreciate your time.
Turning on Enhanced OpenGl seems that doesn´t work ( in 3d max this is much more easier ) so i tried for the tip and it seems it works.
Thanks again!
