splinewrapper 3 (r13): Random Y not showing/working
schemogroby
Messaggio da schemogroby »
Hi everybody!
Sadly the Random Y (or any other of the random parameters) is not working/showing (using "shader > surface > water" as seen in the video). I'm following this video (https://vimeo.com/92452294) step by step, nothing fancy. Any ideas?
Thank you in advance!
(splinewrapper3, c4d r13, OS X 10.10.5 Yosemite)
cappellaiomatto
Re: splinewrapper 3 (r13): Random Y not showing/working
Hi
extract from your scene the part that doesn't work with the plugin and post it here with the attachment system
schemogroby
Hi,
sorry for the delay, i'm just back from holiday.
Please see attached file. Nothing fancy. Most basic setup. When adding "Random Y" + Shader "Water" (or any other shader) the spline disappears.
Meanwhile i had the chance to test it with R15, working fine there.
Thanks for your help!
splinewrapper_test_schemogroby.c4d.zip
(56.47 KiB) Scaricato 509 volte
cappellaiomatto
Hi schemogroby
I have just tested your scene on R14 and R16 and it works perfectly.
Open menù script -> console on your scene and send play to your animation
Check if in the console window some errors appear, if yes copy here the text of the console window.
schemogroby
Hi,
this is what i get from the console (even before hitting play)
Codice: Seleziona tutto
Traceback (most recent call last):
File "'splinewrapper.pype'", line 804, in GetVirtualObjects
AttributeError: 'module' object has no attribute 'InitRenderStruct'
Is there anything more i can do?
cappellaiomatto
also tried on r13 and it works perfectly.
There is something wrong with your cinema 4d installation, may be something wrong with runtime library and/or python lib within c4d because I never see this kind of error in our plugins.
I'm sorry but I cannot help you because it's a specific error with your installation, infact on your r15 it works
the only thing you can do is reinstalling your cinema 4d r13
