[Corona] Corona Releases
A6 RC1
https://drive.google.com/drive/folders/ ... FBpLVF1LTQ
- Corona Renderer 1.5 Core
- Interactive LightMix
- Bloom & glare, filmic tone mapping and other VFB post-processing features (accessible both through Corona VFB and C4D Picture Viewer)
- PBR materials,
- Image denoising
- Much faster displacement processing
- And many, many more (complete list coming with the final A6 release).
A6 RC2
https://drive.google.com/drive/folders/ ... WJhNXpxOUE
- Fixed Bloom and Glare
- Fixed LUT – both installation and missing UI in Render settings
- Fixed LightMix support for Sun and Sky
- Fixed Projector shader
- Fixed bug in compositing of Sky objects (combining multiple Sky objects with compositing tag)
- Minor fixes in installer and materials
- Minor UI Changes
A6 RC3
https://drive.google.com/drive/folders/ ... XhFdF9QNE0
- Corona Renderer 1.5 Core (hotfix 2)
- Fixed termination of rendering in various edge cases
- Fixed various crashes in Picture Viewer
- Fixed color profile handling during post process updates in picture viewer
- Fixed unnecessary updates of post process during camera manipulation
- Fixed post process synchronization after change of active document
- Fixed crashes connected to displacement
- Fixed denoising of non-beauty passes
- Hidden (forgotten) legacy version of multipass from render settings
- Added Enabled checkbox in each pass in Multipass (to allow overriding via Take system)
- Additional layers in Layered Material
- Attempt to fix crashes during material creation (we are unable to reproduce this bug, but we did some changes that could help resolve the issue)
- Attempt to fix crash after denoising finishes
A6 RC4*
https://drive.google.com/drive/folders/ ... DhUUk9pYVE
*Note that this is only a minor update.
Hanno fixato il bug nella creazione di materiali, per il resto è identico alla RC3.
Non è stato risolto il bug durante l' uso di BodyPaint, cambiare interfaccia e lavorare sulle UV al momento crasha di brutto.
Hanno replicato il bug e dovrebbe essere risolto nella RC5, insieme ad altri fix.
Re: [Corona] Corona Releases
Molti stanno aspettando la release ufficiale e, da come si preannuncia, credo spaccherà!!
Così possiamo postare anche i vari test qui sotto... senza discutere nei post personali
Dunque come detto ho portato il software in produzione.... Ho lanciato un rendering stanotte 5500x4500 pixels.
GI/AA 32 LM 2
circa 36 pass il rendering era pulito dopo solo 10 ore (ahahahahaaha)
Inutile paragonarlo a Vray... rendering di pari dimensioni con IM+LC impiega circa 3 ore con BF+LC un 6 o 7.
Comunque non è il tempo che c'interessa.
Ribadisco il mio pensiero iniziale. Corona è un ottimo software e capisco perché molti sono migrati da Vray! Sembra fatto da un grafico per un grafico.... molte cose sono proprio come io le avrei sempre volute in termini di intuitività!
Il WB fa schifo... Su forum dicono che per ora è il WB è gestito dal sistema di C4D ... speriamo bene!
Il solito sborone!!!Anto3D ha scritto:I
WB sarebbe?
White Balancehurricane ha scritto:Il solito sborone!!!Anto3D ha scritto:I
Ho lanciato un rendering stanotte 5500x4500 pixels.![]()
WB sarebbe?
Sul fatto che vray sia più veloce sui grandi formati era intuibile, dato che soprattutto sugli interni le superfici piatte (muri e pavimenti) diventano una bella porzione di pixel.... e li vray vola con IM .... e per assurdo le superfici piatte diventano le più critiche per corona.... sui muri tinta unita gli hot pixel saltano subito all'occhio.
davidecarr
http://www.hammerfish.it
Credo che ci siano buone possibilità he il futuro sia GPU, anche se sinceramente sto perdendo alcune certezze iniziali.davidecarr ha scritto:ora stiamo così.....tra due anni saremo tutti ad usare le gpu.....che dici?
Vedremo come evolve.
Questi motori come Corona mettono molto in crisi software come Vray, che richiedono curve di apprendimento molto lente, facendo della rapidità di setup e della qualità la loro arma migliore. Anche se poi chi ha imparato a fare dei giusti setup su Vray fa rendering a scheggia.
Io ho provato octane per cinema e mi è piaciuto... ma non potendo avere una versione demo completa per testare la sua produttività non ho potuto approfondire.
Il problema attuale delle GPU è il costo. Un investimento troppo importante e troppa poca offerta di software attualmente realmente ottimizzati per il rendering via GPU.
