spline animation issue
Philipp
Messaggio da Philipp »
Hello, I'm creating an animaton with Align to spline TAG but the animation seems to be not continuous. On some parts I see the object running to fast and on some parts to slow. I tried with mograph and there is the parameter to avoid it (uniform) but I would like to use the TAG instead of Mograph because on another computer mograph is not part of the Cinema4D release (Visualize).
Thanks for any help :oops:
Re: spline animation issue
Hi, you should check the spline interpolation method, which is set by default to Adaptive, and set it to Uniform. That parameter represent the internal distribution of virtual points the spline is made of. You may have to increase the "Number" field below to keep the spline's shape.
Philipp
Hey Thank you man! very helpfully :)
