slow viewport
Forum for: Questions about Hardware, Graphic Boards, processors, drivers.
oddworld
slow viewport
Messaggio da oddworld »
I'm experience a slow viewport in some scene i'm working on. I think is time to change my Graphic board (PC). What does my PC needs?
Sorry if this topic has been already discussed ://
Re: slow viewport
First off all you should verify what kind of slowdown does your viewport. There many type of tips on the viewport for speedup the workflow. Do you have many object on your scenes? do you have many deformers or Subdivision Surfaces or Boolean objects?
Try to connect large hierarchy because C4D handle few big objects instead of many little objects. Try to reduce Subdivision Surfaces parameters from 3 to 2 or 1 into the rendering process.
