curtains material
Francycinema
curtains material
Messaggio da Francycinema »
Hi, I have some curtains models to texturize (thanks for the link on other forum section). I watched some tutorial about 2sided material on vray engine. I would like to reproduce it on standard cinema engine.
tips?
^_^
Re: curtains material
Hi Francy, if you wants to replicate the same behavior of the vray 2sided materiale you should pick the backlit shader of effects shader tab and put in into the luminance channel.
So the back face of the object will get light according of the indirect and direct illumination :)
