Moderatori: Arkimed , natas , visualtricks , cappellaiomatto
jackkkk2000
Messaggi: 8 Iscritto il: ven set 14, 2018 11:50 am
Messaggio
da jackkkk2000 » gio ott 11, 2018 4:20 pm
Do you know if Vray does denoise and bloob effects at the same time?
Messaggi: 10608 Iscritto il: ven set 17, 2004 5:34 pm
Messaggio
da masterzone » ven ott 12, 2018 5:09 pm
Yes, if you are using the 3.6 you can do denoiser and effects at the same time, when you apply effects you can see into the dropdown menu the layer "effects results" instead of RGB channel only.
jackkkk2000
Messaggio
da jackkkk2000 » ven ott 12, 2018 5:22 pm
Oh, ok thank you so much, I'm going to try to make post effects...
lucychan
Messaggi: 7 Iscritto il: mer ott 17, 2018 10:57 am
Messaggio
da lucychan » mer ott 17, 2018 11:02 am
Did you try Corona? the Corona denoiser is awesome!
