camera following object issue
AltoFlash
Messaggio da AltoFlash »
hi, i'm trying to make a camera "free fall"
First i tried sticking a simulation tag to the camera, but it didn't work, so i stuck the tag to an object (in this case a cube), and then used xpresso to make the camera's position match the cube's position.
that worked, until i tried to add a floor, then the camera first falls with the cube, but when the cube hits the floor and bounces, the camera keeps falling through the floor and away from the cube.
this is the file, so you can see if there's any glaring error i'm missing: https://drive.google.com/open?id=1owG_4 ... 3_4wbyZL5x
AltoFlash
Re: camera following object issue
well i found the tag on the camera was conflicting with the tag on the cube
did you solve the problem? :)
