C4d R20 non parte più! MAC
Se può essere utile se apro il terminale "Cinema4d Education" mi dice questo:
Last login: Mon Feb 3 15:27:14 on ttys000
MBP-di-Marianna:~ marianna$ /Applications/MAXON/Cinema\ 4D\ R20\ Education/CINEMA\ 4D\ Education.app/Contents/MacOS/CINEMA\ 4D\ Education ; exit;
CRITICAL: error open: file:///Applications/MAXON/Cinema 4D R20 Education/resource/UnicodeData.txt error: Couldn't open file. (file:///Applications/MAXON/Cinema 4D R20 Education/resource/UnicodeData.txt) [iofilehandler_impl.cpp(479)]
Cause: Errno #2: No such file or directory [iofilehandler_impl.cpp(479)] [unichar_impl.cpp(346)]
CRITICAL: Could not initialize unicode table. [xstring_impl.cpp(2568)] [objectbase1.hxx(441)]
net.maxon.kernel: Initialization of net.maxon.interface.application [interface] failed.
net.maxon.kernel: Initialization of main.cpp [translation unit] failed.
(Caused by earlier failure of net.maxon.interface.application.) [object_impl.cpp(2404)]
WARNING: net.maxon.kernel: main.cpp could not be initialized. [object_impl.cpp(3933)]
WARNING: (Caused by earlier failure of main.cpp.) [object_impl.cpp(3936)]
WARNING: net.maxon.kernel: stringresource_impl.cpp could not be initialized because net.maxon.interface.application is missing. [object_impl.cpp(3855)]
net.maxon.kernel: Initialization of datadescriptiondatabase_impl.cpp [translation unit] failed.
Can't initialize datadescriptiondatabase_impl.cpp as it depends on net.maxon.interface.application which couldn't be initialized. [object_impl.cpp(2619)]
WARNING: net.maxon.kernel: datadescriptiondatabase_impl.cpp could not be initialized. [object_impl.cpp(3933)]
WARNING: (Caused by earlier failure of datadescriptiondatabase_impl.cpp.) [object_impl.cpp(3936)]
net.maxon.kernel: Initialization of datadescriptiondefinitiondatabase_impl.cpp [translation unit] failed.
Can't initialize datadescriptiondefinitiondatabase_impl.cpp as it depends on net.maxon.interface.application which couldn't be initialized. [object_impl.cpp(2619)]
WARNING: net.maxon.kernel: datadescriptiondefinitiondatabase_impl.cpp could not be initialized. [object_impl.cpp(3933)]
WARNING: (Caused by earlier failure of datadescriptiondefinitiondatabase_impl.cpp.) [object_impl.cpp(3936)]
WARNING: net.maxon.core.framework: cpuid.cpp could not be initialized because net.maxon.interface.application is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: mac_tools.mm could not be initialized because net.maxon.interface.language is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: mac_tools.mm could not be initialized because cpuid.cpp is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: mac_tools.mm could not be initialized because net.maxon.interface.application is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: ansi_system_process.cpp could not be initialized because net.maxon.interface.application is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: iocache_handler_impl.cpp could not be initialized because net.maxon.interface.application is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: configdatabase.cpp could not be initialized because net.maxon.interface.application is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: configdatabase.cpp could not be initialized because cpuid.cpp is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: moduleversioninfo_impl.cpp could not be initialized because net.maxon.interface.language is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: urlfile_cache_impl.cpp could not be initialized because net.maxon.interface.application is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: datadescriptionobject.cpp could not be initialized because net.maxon.interface.language is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: localmachine_impl.cpp could not be initialized because net.maxon.interface.application is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: system_impl.cpp could not be initialized because net.maxon.interface.application is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: datadescriptiondefinitiondatabaseurl_impl.cpp could not be initialized because net.maxon.interface.language is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: datadescriptiondefinitiondatabaseurl_impl.cpp could not be initialized because net.maxon.interface.configuration is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: datadescriptiondefinitiondatabaseurl_impl.cpp could not be initialized because net.maxon.interface.application is missing. [object_impl.cpp(3855)]
WARNING: net.maxon.kernel: api_summary.cpp could not be initialized because net.maxon.interface.application is missing. [object_impl.cpp(3855)]
Application couldn't be initialized!
CRITICAL: Stop [general.cpp(629)]
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Processo completato]
Re: C4d R20 non parte più! MAC
scusa hai provato a cancellarlo e reinstallarlo?
Deve essere successo qualche pasticcio, devi cancellare tutta la cartella PREFS ma devi cercarla nel computer, fai cosi':
Vai sulla scrivania del MAC, e fai cosi:
1) tieni premuto il tasto ALT e apri il menu VAI che c'e' sulla barra in alto del Mac (devi sempre tenere premuto ALT). Mi raccomando dal menu del Finder (scrivania) non dal menu del browser o altro.
2) ti comparira' insieme alle classiche voci di menu; documenti, desktop, anche la voce "LIBRERIA" che e' l'unica sanza scorciatoia segnata.
3) clicca e ti si aprirà nel Finder la finestra LIBRERIA
4) cerca tra le cartelle quella che si chiama "PREFERENZE"
5) dentro quella cartella trovi quella chiamata MAXON
6) buttala nel cestino tutta quanta (la cartella MAXON).
Riprova
