Measure plugin requests
mikeh
Messaggio da mikeh »
I think for any sort of visual design work the inability to have the text be an extrude vs the way it is a sweep must be changed. There are probably almost zero situations where an art director would be happy with the look of the tube/sweep/double line look of the text. It would also be nice to be able to access the spline settings of the Measure it object to improve spline quality as it is very chunky as is.
Also, the text needs to stay centered between the measure points. In my case if a simple create measure it wizard and simple move one of the end nulls the text eventually ends up above one of the nulls.
Could be a great tool but needs a few updates.
cappellaiomatto
Re: Measure plugin requests
Hi miken
Thanks for suggestions, I will evaluate them in the next months, at the moment I'm very busy
Best regards
Matteo
mikeh ha scritto: ↑mer lug 28, 2021 4:03 pm I think for any sort of visual design work the inability to have the text be an extrude vs the way it is a sweep must be changed. There are probably almost zero situations where an art director would be happy with the look of the tube/sweep/double line look of the text. It would also be nice to be able to access the spline settings of the Measure it object to improve spline quality as it is very chunky as is.
I remember that during the Wizard you can choose if you want the extruded object or sweep object, so you will able to avoid the double lines of the sweep objects :)
