Different UV’s for color & alpha on the same material
Milincho
Messaggio da Milincho »
For the same material I need to use one texture with a UV set on the color channel and a different texture with a different UV set in the alpha channel… how can I do that?
Re: Different UV’s for color & alpha on the same material
Dear Milincho, With Cinema4D standard material I can't find anything about UVW selection. Otherwise on Redshift you can assign a node texture to a specific UVW TAG...
