C4D crash on main (165Hz QHD) monitor but works fine on others (60hz HD & QHD)
Is this a known issue or is there maybe some setting that I need to change or any known or less known fix for this problem?
I have tried downloading various different versions of C4D but they all have the same problem.
When I open C4D and I hover over one of the various tools, it gives me the info of what tool it is but it blackens my entire screen and in small letters on top I can see the explanation of that tool, whereas this behaviour is very different when I do the same on my other monitors. There it just gives me a little piece of text with the explanation, as it should be. As soon as I click on anything (when it’s on my main monitor) the software crashes.
It would be so nice if anyone could help me out and fix this issue.
Thank you!
PC specs:
Win 10
Nvidia Geforce RTX 3060 (been waiting for my 3080 for over a year now, but that’s a different story)
Intel® Core ™ i9-10900K CPU @ 3.70Hz
MOBO: Asus ROG STRIX Z490-SO
Monitors:
MSI G27CQ4, Res: 2560x1440, 165Hz (this is the one that crashes C4D)
BenQ LCD, Res: 2560x1440, 59,951Hz
iiyama PL2377 , Res: 1920x1080, 60Hz
Re: C4D crash on main (165Hz QHD) monitor but works fine on others (60hz HD & QHD)
What about drivers? and windows? do you have a fresh installation or your windows 10 is outdated? sometimes reinstall a fresh windows with fresh drivers helps...
Anyway never heard about it...
Ok you have a lot of monitor but you have also a good graphic board...
