Grass Painter : Paint Objects
With grasspainter how can i paint personal objects (rocks, trees, grass path,...)
The type of the object .c4d, obj ????
Thanks a lot !
- cappellaiomatto
- Moderatore
Re: Grass Painter : Paint Objects
Sorry I don't understand, can you explain better what do you need?
Do you want to paint for example a rock ?
or
use grasspainter to place rocks on then ground?
What is the format of this "user file" ?
I want to use it to put gravel or little rock randomly on a surface for example.
Thanks
- cappellaiomatto
- Moderatore
You have to paint only one single pixel otherwise you put a lot of rocks in one single point.
Use low poly object because it could take a long time to placing objects
Within the plugin folder there is a folder dedicated to user object....(custom if I remember correctly)
Put your custom objects in c4d file.
One file for each object (rock.c4d, tree.c4d)
Take a look at the pdf manual inside the zip package you download from our store, the procedure is explain inside it.
I have finding the "custom" folder and 2 .c4d files
Thanks for your help
