Applying Effectors to OBJ sequence importer
Just bought the OBJ sequence importer plugin and imported a big ol' 900 obj sequence into c4d flawlessly, now I'm trying to find a way to crop the sequence in 3d space. I'm attempting to use the volume effector on the sequence but am not having much luck finding a way to apply it.
Any tips out there on how to do so, or alternative methods? (I'm looking for an effect similar to the volume select modifier from 3DS Max, where I can create a polygon and essentially say anything outside of that space in each frame of the sequence is invisible or deleted)
thanks!
Steve
- cappellaiomatto
- Moderatore
Re: Applying Effectors to OBJ sequence importer
you can do it with xpresso.
if you upload here a couple of frames I will send you back a demo scene with the xpresso preset
