QuadCaps r25
raulofs
QuadCaps r25
Messaggio da raulofs »
QuadCaps 1.0 C4d 25 not working.
How can i make it work?
Traceback (most recent call last):
File "C:\Users\user\AppData\Roaming\Maxon\Maxon Cinema 4D R25_1FE0824E\plugins\c4d25_bridge\quadcaps\quadcaps.pypv", line 1331, in <module>
File "C:\Users\user\AppData\Roaming\Maxon\Maxon Cinema 4D R25_1FE0824E\plugins\c4d25_bridge\quadcaps\quadcaps.pypv", line 96, in getinstnew
In the order page I tried to download it again, but it does not work
cappellaiomatto
Re: QuadCaps r25
Hi
I'm not sure of the installation path
did you download the latest zip package from your order?
if yes within the zip there are many versions of the quadcaps, extract the right folder for your c4d version.
put it inside your document folder or desktop or wherever you want.
within the c4d settings add this path to the plugins path.
than try to activate the plugin and see if it works.
reply me directly via email
matteo @ c4dzone.com
I wait for your reply
Matteo
