create a new vertex map from 2 different maps?
losDominos
Post by losDominos »
Can Vertex Map Animator take 2 different vertex selection maps and create a new vertex map? From what I can see it should be able to do this simply by stopping the animator in transition between them. Is this correct? Does anyone have any examples of this?
Thanks.
cappellaiomatto
Re: create a new vertex map from 2 different maps?
Post by cappellaiomatto »
Hi
I will upload an example scene as soon as possible....I'm a little bit busy in this period pfiu
cappellaiomatto
Hi losDominos
I have got some time to help you but I need to understand better your request
Can you explain me the effect you want to obtain with the plugin ?
Vertex map animator take a map as input -> apply some effect on it -> write the output on another map
this means that if you want to operate with many maps you have to pipe them
Example
Input map A -> write on B
Input map B -> write on C
etc etc
I wait for your reply
Matteo
