Fold It - Weight Map is Empty
Hi) I need some help with Fold It plugin. Suddenly it stopped creating a weight map for mesh. When I used it for the first time everything was fine), but now I have to paint all weights by myself. I also tried it in R25 - and it had the same issue. Any advice?))
- fold it weight.jpg (32.32 KiB) Visto 39825 volte
- fold it empty.jpg (28.34 KiB) Visto 39825 volte
- cappellaiomatto
- Moderatore
Re: Fold It - Weight Map is Empty
Matteo @ c4dzone.com
I will check it and reply you as soon as possible
cappellaiomatto ha scritto: ↑mer dic 15, 2021 8:47 am Can you send me your example scene at
- FOLDIT_001.zip
- (88.55 KiB) Scaricato 1605 volte
- cappellaiomatto
- Moderatore
the plugin works correctly
you miss the selection before adding the fold
https://www.c4dzone.com/en/shop/plug-in ... -0-257.htm
watch the video demo at 0:42,
you have to select the edge to fold and the polygon face associated before the add fold operation.
the selections will become the weight of the joints.
Matteo
- FOLDIT_001.zip
- (85.52 KiB) Scaricato 1486 volte
cappellaiomatto ha scritto: ↑mer dic 15, 2021 8:38 pm Hi
Matteo
You're right!)) That was my fault... Thanks for the help!!!
But there is another issue). When I "Add Fold " I can't change the length of the arrow from the viewport, only from the attributes panel. This happens only in R23, in other versions everything is fine).
- Can't change the length video.zip
- (409.82 KiB) Scaricato 1668 volte
- cappellaiomatto
- Moderatore
this particular feature is not compatible anymore, maxon changed something in the api and at the moment I haven't release a patch for fix that.
Ok thank you!!!cappellaiomatto ha scritto: ↑gio dic 16, 2021 7:52 am Hi
